I am currently in the process of milling a recess in a block on the basis of an STL file. In principle it works, but what I don’t understand is that the tool head always traces the full workpiece surface linearly and then only adjusts the Z-axis accordingly . Even a round hole is created from parallel lines and not by a rotational movement. Is this because Luban is not really suitable or am I using unsuitable input data? Or is it something completely different?
