This time it worked all of the way. Roughing pass with a 6mm end mill, followed by a cleaning pass with a 1mm Ballnose and a finishing pass with a 0.25mm Ballnose. CNC file created using vCarve with the Snapmaker post-processor.
Dry fit in place before staining to match the original timbers.
MarkJ
August 25, 2025, 12:27pm
2
Nice!
What were your run speeds and time?
I don’t remember the roughing pass, but the clearing path was about 4 hours and the finishing pass about 2 hours. ~12K on the spindle
nweolu
August 25, 2025, 1:27pm
4
THis is nice, What cnc module you used?
I upgraded to the 200W model on an A350
Where did you get the image from?
I bought it from an artist on https://www.renderhub.com . But the list of useful places to look for cool models is huge… Some quick examples
MarkJ
August 25, 2025, 4:29pm
8
Thanks. What was the toolhead movement speeds/work-speed (mm/min)?
I’m assuming that is oak?
Yup - oak countertop leftovers from a kitchen renovation.
According to the vCarve settings, I was at 12K RPM on both ballnose passes, the 1mm was at 12mm/sec and the 0.25mm was at 18mm/sec
BJP
August 27, 2025, 3:50pm
10
Fairly sure that is beech not oak - but a nice piece of work - congratulations.
Good call on the beech. Just checked and there were leftovers from two different projects, one beech and the other oak
