Circuit diagram linear module? or why my linear module is broken
Is there a circuit diagram of the linear module. According to the print on the circuit board, two diodes are missing from the motor to protect the driver from overvoltage. Is that wanted or is it a production error in the assembly. As I understand it, the lack of diodes can cause the motor driver to experience an overvoltage under a slightly higher load (through short movements) and thus destroy it. So that a damage pattern occurs as with me, that the axis is a total failure.
Can you provide a picture?
the desired picture, please :grin:
note the blown hole in the circuit. There the magical blue smoke came out.
I am of the opinion that the protective diodes at the output to the motor windings are missing. They can be seen on the right in the attached circuit diagram
L298standard
Interesting, SM didn’t put flyback diodes on the cooling fans either… though this seems like a much larger design flaw.
I took another picture of the circuit exploding. So that you can see correctly that it is a defect and not a production hole. You can see the broken edges nicely. Since most stepper drivers have an integrated overload protection at too high a temperature or too high currents, only overvoltage is an option for me. I also see the danger with the fan motors. There, however, the stress may not be so great because there is no reversal of the direction of rotation and the load changes are not so rapid.
2020-10-18-084157
I’m wondering whether the decision to put the circuits inside the module was a mistake.
Stepper motors create a lot of heat. Why not place the driver inside the controller or as part of the splitters or as it’s own separate unit?
Perhaps there’s a way to retrofit this?
Hey dumb question here, but since I’m having trouble reading the IC markings…
Is that the canbus mcu and not the stepper driver? I was under the impression the stepper driver was an a3988 which I don’t see those markings on that chip.
That chip looks like it has way too many pins to be the stepper driver.
@brent113
I once marked the conductors from the circuit to the motor connection in color. Several pins are brought together on the circuit to reduce the current load on the individual bond wires.
2020-10-18-092649
The designation on the circuit is:
5109AFTG
1921H
EQ9644
JAPAN
@sdj544 Integrating all the control electronics into the module is okay. The housing is made of aluminum, which sufficiently dissipates the heat from the engine. Attempts were also made to dissipate the waste heat from the stepper driver, but in my opinion this was not optimal. The silicone thermal pad has a tendency to slip. A longer ribbon cable between the two boards would allow the stepper board to be securely mounted on the housing. Or make the mechanical connection of the two boards elastic, so that a spring pressure is always applied which presses the stepper board against the housing. Conductive paste would be sufficient in both scenarios.
Alert: rambling ahead as I try and understand what you’ve already figured out. No conclusions drawn:
Ah, it’s a TB67S109AFTG stepper driver. Thanks for that. Datasheet and Application Note here, if you haven’t found it yet.
Those two empty solder pads you traced are for the OUTA+/- and OUTB+/- pins to the motor. The typical application does not have clamping diodes, so this design closely matches the reference design:
Flyback handling is done by the driver internally:
Anyways, about the only thing I can’t tell yet is if the power supply is fused like the datasheet recommends. Other than that the design seems fine.
Thanks for the Datasheet. I must read it.
edit: From Datasheet.
“While a motor is rotating, there is a timing at which power is fed back to the power supply. At that timing, the motor
current recirculates back to the power supply due to the effect of the motor back-EMF.
If the power supply does not have enough sink capability, the power supply and output pins of the device might rise
above the rated voltages. The magnitude of the motor back-EMF varies with usage conditions and motor
characteristics. It must be fully verified that there is no risk that the TB67S109A or other components will be damaged
or fail due to the motor back-EMF.
When a motor reverses direction, stops, or abruptly slows down, current flows back to power the motor
due to the effect of back emf. When the power sink capacity of the power supply is small, the motor output of the device is increased
Supply and output pins can experience conditions in excess of their absolute maximums. To avoid this problem,
Consider the effect of back EMF in system design.”
That would explain why the module failed precisely on the part with many short internal structures.
If the cable and the connectors are not laid out correctly, loose contact. And 47µF as a block cap?
Based on the EMF thing, what diodes would you reccomend? I dont like verry mutch to start soldering in a Product this expensive but if it stopts it from becoming scrap ill do it if need be. Hopefully we get a statement from SN at some pointif this becomes a bigger/major problem.
According to the design, anti-parallel Zener diodes were provided there. I can’t say which it should be now. For this we would have to see the original circuit diagram of this layout.
Just to be clear here, EMF is the old term for what we now generally call “volts”. Sounds fancy though. Short for electromotive force, back from before the unit getting renamed to honor Alessandro Volta’s work. Literally - the “force that moves electrons”.
from datasheet:
If your design includes an inductive load such as a motor coil, incorporate a protection circuit into the design to prevent device malfunction or breakdown caused by the current resulting from the inrush current at power ON or the negative current resulting from the back electromotive force at power OFF. IC breakdown may cause injury, smoke or ignition. Use a stable power supply with ICs with built-in protection functions. If the power supply is unstable, the protection function may not operate, causing IC breakdown. IC breakdown may cause injury, smoke or ignition.
I can’t afford a private firefighter. :grin: :man_firefighter:
Hopefully this link works right. The preview is showing up strangely. Someone on FB has done some testing on his module:
It’s no fun if there’s no possibility of injury, smoke, or ignition :rofl:
That circuit symbol on the PCB silkscreen is for a TVS diode, yes, literally back to back zeners. Something like this would be typical. Given the 24V application limit that may be able to be reduced, but you generally want some headroom. Also I haven’t confirmed the pad size.
Housing size SOD323 fits. Only i would look for 40V types
I have not a facebook account.
