hi there
i got an issue
i want to calibrate the flow of extruders
i can enter G1 E50 F300 just 1 time… if i want to test it again… i need to electrical reset the printer
and im always flooded by unknow command M1010, M1012 and M1007
all day long, new usb drivers installed, new ch340 drivers… when i try to connect that tell me that the device are not recognized that do this on 2 computers (printer firmware updated too)
That’s because the machine defaults to absolute position mode. You told the machine to go to E50, which it did. Doing it again tells it to go to E50, which it’s already at, so it doesn’t move.
@xchrisd is correct, you will need to be in relative mode to do additional tests.
M1010 is apparently checking for the enclosure status, so that’s Luban checking if you have an enclosure. It saying unknown command is odd, ensure your firmware is fully up to date. M1012 is checking for the e-stop button. M1007 is checking axis information to figure out if it’s been homed/where the toolhead is.
Your best bet is to update the firmware on the J1 fully, and updated Luban fully. If it’s still throwing all the errors, contact support@snapmaker.com.
Does Luban even offer a fully functional serial terminal?
Last I checked, you can send commands with it, but most commands did not get their reply shown properly.
This was a year ago, but support told me to use Pronterface for a full terminal. An OctoPrint server also works. Otherwise most commands only replied “ok”. The history of this problem is one of the more absurd ones…
This doesn’t fully answer the expected, actual machine response though. To my knowledge the commands still sent, you just didn’t get the response on the terminal.
