I setup Wifi on Snapmaker2 and I can connect via Luban. I also can turn on the enclosure LEDs, put Snapmaker to home location all via Luban. I can confirm Wifi connection on touch screen, but other than that I am either on details screen when connected to Wifi or on Laser Getting Started guide screen when Snapmaker2 starts. I can click on touchscreen and get through the guide, jog the head around, but swiping left to get to Settings does not work. And yes, I did try “other left” And even up and down. I removed protection foil over the touchscreen in case that would be the problem.
So my question might seem basic but: How do I access “Home” screen or “Settings menu” on Snapmaker2 touchscreen?
It is on Getting started for the Laser, and I can click next, set material thickness, then jog around to origin point and set origin and stuff, but I thought I can access settings from anywhere? Do I need to finalize calibration first?
OK, so here I am answering my own question. Until head is not calibrated you cannot access Settings or Home menu.
From my perspective, this is strange, as I would like to run a firmware update before doing anything. Now laser and camera is calibrated with old firmware, and I will probably recalibrate it just in case.
oh thats cool so the CNC didnt make you do any kind of calibration first? if thats the case this is something i will for sure tell people when they have a problem like this
