Calibration of complete Bed Size
Hello Snapmaker,
Would it be possible to have e.g. a 10x10 calibration pattern which covers complete bed size including all corners?
Cheers
Apper
It was a common problem in the past that the bed was not level cause of 3x3 calibration.
Have a look here:
Would like to see it in the firmware, guess it would be just another option in the code.
Instead of juggling around with G-codes.
In this case shoot a ticket and mention your request:
Email support@snapmaker.com or ticket
I made a ticket but the request was put on the endless pile of requests.
Bed size mm2: 320mm x 350 mm = 112000 mm2
Mesh bed: 5 x 5 = 25 mesh point
So: 112000 / 25 = 4480 mm2/mesh point
One mesh point must cover a square of 66.9 mm x 66.9 mm…?
So we measure the Z-distance to 0.05mm in the middle of a 67x67 mm square
and interpolate over 2 x 67 = 134 mm distance between two mesh points, and that is going to be
accurate on an over and over used heated/scraped/used print bed??
It’s 6x6 since a while now but you are totally right..
