Bed level
I’m not sure this will be useful to anyone, but after recently deciding to check the bed warping of my F250, I ran the M420 V command and saw a bunch of numbers. Since I was too lazy to dig into them, I just asked Copilot to visualize the bed map from the data — and voilà, I got a 3D map clearly showing the full horror I felt when I saw how much deviation there actually was. So, the reason I’m writing all this is simply that it might be more convenient for someone to generate a bed map using AI rather than processing the data manually.
If you want to go down the rabbit hole of Snapmaker 2.0 bed levelling, here some recommended reads:
This would also worth try for the dual extruder:
