Calibration of A350 dual extrusion head
Can someone help me with this? Trying to calibrate for a new dual extrusion head on an A350 printer. This is what I’m getting.
I have run the calibration several times, and it’s not getting better. I can’t see any obvious operational problem. I routinely run a single extrusion A250 and get great results.
You have to lower the white nozzle. Printing is to high. Black also. Not that to high, but also.
Yes, thanks for the obvious answer I didn’t follow through on. I drilled into the control menu and found the manual adjustments. Getting close now.
Yeah, the z Level auto calibration is not that good. For me I have to manual lower for like .1 to .4 mm
