Cable Sleeve problem
Has anyone else experienced problems getting the cable sleeve that comes with the Artisan to contain all of the cables? I have some extra long y axis cables apparently as well as some others that are quite a bit longer than the toolhead cable was so I have to double up on the cables in order for them to fit the length of the sleeve but then I just can’t get the sleeve to zip all of the way up because the cable bunch has become to thick.
Yeah, all cables have different length, you can just buffer the long ones at touchscreen or inside the enclosure… cable management in Artisan is worse than in 2.0… Not possible to get a clean look.
