[BUG] Snapmaker U1 Firmware 2.1.0 – Touchscreen goes black during printing and won't wake up
Update:
Our engineer has released a beta firmware to resolve this issue:
V2.1.0_158
V 2.1.2.159-Updated 11.10
If any users here have encountered a similar problem, please install this beta firmware and let me know if it works for you.
Best regards.
Hello, support sent me the firmware via technical support as well, due to the same issue.
I’ve installed the firmware and will see how it goes.
In addition to reporting the results to technical support, I’ll comment here in case it helps others.
Thanks
Yes please.
Same here. If I press and hold the top-center it will turn off the backlight, then go back to a blank screen. It just randomly happened only a minute or so into a print, during the initial calibration.
Hi, have you tried the V2.1.2.159 beta firmware here:
At the same time, could you please submit a ticket to our technical support with the follwing details:
Wait for your reply.
Best regards.
I’ll try the new firmware and update if it keeps happening.
I can confirm this issue on multiple Snapmaker U1 printers after updating to firmware 2.1.0.
I own five U1 printers, and this has already happened several times on different machines.
After a print finishes, the touchscreen sometimes refuses to wake up. I can tap it repeatedly, but absolutely nothing happens.
The only way I’ve been able to use the printer again is to turn it off using the rear power switch and then turn it back on.
This is extremely frustrating, especially when operating multiple printers and starting new print jobs throughout the day.
Why are such basic functions breaking after firmware updates?
@Zoe_M, is Snapmaker aware of this issue, and when can we expect a proper fix?
Thanks for your confirmation of the problem, but if you read the thread you will see the problem is being addressed. Feel free to test the fix:
You will need to download it and apply to the U1 from a USB stick: Settings > About > Firmware Version > Local Update.
Alternatively, set your screen timeout to “never”.
Thanks for the information! I’ll try the beta firmware now.
It just happened again (using that firmware you shared). When I touched the screen, it suddenly went black again like before. I’ll try it again with the newest firmware you’ve shared here (11/10).
After update it happened again….
Hi, did you install the 2.1.2.159 beta here and the black screen happended again?
Could you please submit the U1 log to our technical support team(https://snapmaker.formcrafts.com/u1-troubleshooting-request):
I’m also experiencing this issue after the update… I couldn’t wake the screen from standby… I managed to wake it up by pressing the middle of the screen for a few seconds…
I’m waiting for a general update, so I’ll have to cope for now… It would be good if this was resolved soon as it’s quite annoying. Also, having an option in the web client to wake the printer screen would be useful…
Hello, after using firmware V2.1.0.158, which I obtained from technical support, for several days, the screen blackout issue has not recurred. However, I see that you have replaced that firmware with a newer version.
Should I update, or should I stay on version 158?
@Ralu
Hi, there will be a stable release-V2.1.2 in the next week. so I think you can stay on the V21.0.158 for now.
ok, thanks
@egg.me , thank you for the feedback. Do you refer to V2.1.0_official release right? Not the latest beta 2.1.2.159
the official one offered via the printer
It’s really very simple: set your screen timeout to “never”.
Its even easier than that, don’t test beta FW’s if you can’t afford to have downtimes/risk bricking your machine :exploding_head:
Sadly SM has form for fixing one bug and introducing 3 more - I actually do wonder if they internally test these releases or whether they just cross their fingers & see what happens??
