I have read and understood all rules of the Innovation Fund Phase 2
on
I consent to my project information (username, project cover, summary, etc.) being publicly displayed for review and showcase
on
Username (for public display)
J0eB0l
Project name
BridgeBox: run any stock Bambu AMS on your Snapmaker U1
Project URL
Project cover
Project Category
Hardware MOD
Project Summary
The U1 is a great machine with four toolheads, but four spools is where it tops out. BridgeBox lets you put a stock Bambu AMS behind a toolhead, so that one toolhead can pull from up to 24 spools. Give another toolhead its own BridgeBox and you get even more. At that point the slicer is the limit, not the hardware. And a lot of us already have an AMS sitting on a shelf.
BridgeBox is a small board that plugs into the AMS exactly where a Bambu printer would. From there, the AMS is run by AFC (AFC-Klipper-Add-On), the open source filament system the AFC Project team has spent years building and refining. It already drives BoxTurtle, HTLF, ACE, ACE 2 and more, and it already runs on the U1. BridgeBox makes the AMS one more unit AFC can drive, built hand in hand with the AFC team, so it gets AFC’s loading, error recovery and Spoolman support on day one.
And you never touch the AMS. No opening it up, no swapping boards, no custom firmware. Unplug BridgeBox and it goes straight back on a Bambu printer.
What it means for U1 owners:
- More colors and materials: one BridgeBox feeds a toolhead from up to 4 AMS units plus 8 HTs (24 spools). Want more toolheads on AMS? Add a BridgeBox for each. You can even run more than one into a toolhead through a splitter, though at some point that’s overkill
- No USB cable to the printer: BridgeBox talks to the U1 over WiFi, with no keys to type during setup. USB works too
- Backup spools: when a spool runs out mid-print, AFC can switch to a matching one and keep printing
- Less typing: Bambu RFID tags fill in material, color and temps, and Spoolman remembers each spool in whatever slot it lands in
- Dry filament where it lives: dry on the AMS 2 Pro or HT from Fluidd or Mainsail and watch temperature and humidity
- Works with the AMS 1, AMS 2 Pro, AMS HT and AMS Lite
BridgeBox has been in development for months and is finally ready for public release. It was developed and tested on my own U1, alongside a BoxTurtle, an ACE and an ACE 2, all under AFC. And it hot swaps: plug an AMS in or pull one out while the printer is running and BridgeBox picks it up on the spot. No restart, and your tool numbers and spools stay put.
There’s also optional firmware for the BTT Panda Touch / K-Touch that shows every lane, spool and dryer on the printer.
What the fund would go toward: building the next batch of BridgeBox boards, and adding more AMS units to my test bench so every model keeps getting tested on real hardware before it reaches your U1.
Full page: BridgeBox
AFC: GitHub - AFCProject/AFC-Klipper-Add-On: Automated Filament Changer Software · GitHub
Open Source Status
Closed Source
Please specify the open source license used by this project
The transport protocol module and board firmware are closed source, the rest of the software is opensource as it pertains to AFC.
Cash Fund or U1 Hardware Sponsorship
Cash Fund
Originality
Original New Idea
If based on an existing project — your independent contribution
I designed the BridgeBox board and its firmware, and built the AMS support in AFC together with the AFC team.
Is it a paid project?
Yes
