Bed temperature does not continue to heat throughout the entire print
Are you sure your bed stops heating? Curling of the corners may happen even with the bed still hot. If your bed rally would stop heating because of a technical issue, the printer would stop with a thermal runaway warning. So either your bad is warm but you still have warping (solutions would be a larger brim, or something like this), or your GCode sets bed temperature to 0 - in this case, watch your slicer settings - most slicers have an initial bed temperature (first layer) and then a follow-up-rest-of-the-print temperature. This may in your case be set to 0.
That’s a “known issue” - several solutions here in the forum - here is mine: Magnetic print sheet fixation - #10 by Hauke
