Bed screw manufacturing defect
While assembling my A350 I discovered that one of the screws for the 3d printing bed failed to have the head punched out correctly, so it was impossible to fit a screwdriver into. Does anyone know where I might be able to get a replacement screw? Tried looking online to no avail. Should I contact support?
Thanks.
I only have a v1, but all the bolts on the v1 are metric M4 of various lengths. I bought some more from amazon. The head doesn’t quite match the cylindric head, but they work fine and use the same driver as the OEM bolts.
I can’t remember, are the bed screws M4 countersunk? If so, check out these:
Depending on where you live your local hardware store probably has some little trays/cabinets of misc. screws and repair parts.
Should be a metric section.
