A good point. I verified mine previously and would recommend others do as well. My towers were level and parallel, within what I would consider an acceptable tolerance:
I saw you? recommend loosening the bolts on the Z tower X-axis mounts for the first adjustment: I also agree with that, and also did that to relieve any residual strain. You should want any strain to be pulling it back into square instead of out.
