Hi I have a probem with axes control, just put the snapmaker together upload the new software and tried to level the printer. But the axes did not move. Also with the control the axes can not be moved. When I change the cables from the Z and Y axes and restart the system I can control the axes. But they are wrong than for printing. Do somebody have the same problem and how can I fix it. Thanks
Are the axis installed correctly?
They are no longer all interchangeable.
The z-axis are marked 8mm lead. They y & x are marked 20mm lead.
Thank you,
yes it was my fault, it is working now.
Thanks once again
Christian
