@Snapmaker-Support do we have model files (STL is fine) for the print head tube clips? I lost 1. Prob easier to reprint them than to have you send physical versions?
If not, that doesn’t look terribly difficult to model. A good first project if you’ve never done it before.
With some calipers, I could slap that together in about 10 minutes in TinkerCad… better make it 20 minutes….
Professional designer, just short on time. +Tolerances for a piece like that will be ~0.1mm, no need to start from scratch if it’s available.
If your really keen, us a .2 nozzle on using fine settings with a brim.
Artisan Clip v1.stl (68.4 KB)
Threw this together in shapr upon your post, feel free to test it.
Filament Tube Clip for Snapmaker Artisan by Rubber3Dragon - Thingiverse
Appreciate it, should save me a few minutes. I won’t be able to test for a while unf but if nothing else, thank you from the other end of the internet.
