Artisan and pillowing
Need your . Can’t find a solution for pillowing in my artisan. I’m using cura slicer. Infill 15% and ironing. Any good solutions to avoid this problem?
Thanks
Mirekm
Increase the number of top layers or increase infill percentage.
You can also try to decrease the top layer speed. 15% infill should be possible. Also check your esteps and flow settings in general.
Best :v:
I have better luck with some of the 3D infill styles, like Gyroid. It’s my default style now.
If you use a slicer that supports it (Luban doesn’t), you can increase the infill immediately below the top layers without needing to increase it for the entire print.
I had a similar problem when trying to print some parts that required 100% infill. The problem was over extrusion. I had to back the flow rate down to 90% with generic PLA.
I need to thank you all for suggesting. Now it is much better. Changed infill to gyroid, 20% and corrected last layers. Much better :slight_smile:
