Artisan 40W Laser Control Using Lightburn Macros
Good evening,
I’m curious if there is any Macros available to control the Enclosure Fan and Air Purifier? Also a dwell function to use in Lightburn would be nice so that I could get the Start Code to automatically turn on the Air purifier and exhaust fan and then delay turning them off after completion. I’ve already gotten the Crosshair Macro (M2000 L13 P0) to turn that off when starting a project, I would just like to have all of the other functions to turn on/off automatically…
I did not see these macros when looking in the Luban Workspace console. I’ve also searched the forums and asked AI to no avail. Is this only an HMI function? I have had issues with the Controls disappearing (except for the move menu) on the controls screen/having to reboot to bring them back up. It also causes lag when turning the air purifier and exhaust fan on while running g-code in Lightburn.
Thank you for any suggestions/comments,
SP
To control the air purifier the gcode is as follows;
M2000 W42 P1 (This turns the Purifier on P0 turns it off)
M2000 W40 P3 (This controls the speed, P1-P3 for low to high)
To wait, that’s simply a G4 command. Its flags are Px and Sx (P being miliseconds, S being seconds)
G4 P1000 (pauses for 1000ms)
G4 S1 (Pauses for 1s)
Effectively the above two commands should be the same, but place it in the footer gcode before your purifier off gcode.
G4 S300
M2000 W42 P0
The above gcode waits 5 minutes (300 seconds) before sending the command to turn off the purifier. As far as the fan goes, I’m not sure. I don’t have an artisan to do tests with to try finding which flag controls the fan.
However; there’s a macro in the Ray lightburn profile that might work to turn on/off the enclosure. Might be worth testing.
"Macro4_Content": "M2000 W5 P0 Q0\n",
"Macro4_Label": "Enable Enclosure",
"Macro5_Content": "M2000 W5 P1 Q0\n",
"Macro5_Label": "Disable Enclosure",
Though, I would have figured P0 would have disabled, not enabled it. Couldn’t hurt to poke support@snapmaker.com and ask, or maybe @Jade ?
Thank you! The Air Purifier is working as intended. Tried different configurations of the other ones for the enclosure but received errors:
M2000 W5 P0 Q0
[hmi_set_enclosure_check] got a invalid parameter
invalid sacp hmi channel[21]
ok
M2000 W5 P0 Q0\n
ok
M2000 W5 P1 Q0\n
ok
M2000 W5 P1
ok
M2000 W5 P0
invalid sacp hmi channel[49]
ok
However, it’s not totally necessary; as long as the purifier is working, it will drag the fan along with it. Thanks again!
