I’ve been using the BIQU CryoGrip Pro Glacier for at least six months now.
Pros:
PLA, PETG, and TPU stick extremely well.
ASA and ABS also have good adhesion, although not quite as extreme as PLA, PETG, and TPU.
The surface has a finer texture, which can be an advantage depending on what you’re printing.
Cons:
PLA, PETG, and TPU stick extremely well. Sometimes a little too well, making support structures very difficult to remove from the build plate.
At first, the AI spaghetti detection also struggled with the blue surface and frequently generated false-positive alerts. I therefore keep the detection turned off.
In general:
The plate needs to be cleaned regularly with soap and hot water. I usually apply plenty of soap and scrub it thoroughly with a brush.
Over time, I’ve had to gradually increase the build plate temperature again, and I now always select Textured PEI Plate as the build plate type in the slicer.
I’m still using my very first plate, though. The coating has never peeled off by itself. There are only a few small damaged spots caused by scraping prints off with a metal spatula.
I’ve been using two Biqu Frostbite plates. Each plate is reserved exclusively for PLA and the other for PETG to avoid having to clean them. This works wonders. However, I noticed the plates still had adhesion issues at the ‘cool’ temps with both filaments so I end up still printing at higher bed temperatures.
On the upside, printing at higher bed temps, the adhesion is phenomenal. And the release is also great when only cooled down, even for just a few minutes.
The textured PEI plate that came with the machine is reserved for TPU prints with 3D Lac as a release agent.
I’ve seen them advertised on the likes of Aliexpress from Chinese companies I know nothing of - I don’t /think/ I can recall seeing anything from the major build plate brands as of yet for the U1…
Like alot of things though companies marketing like to use vague terms & Eibos call their new Krios build plates COLD even though they start from 40c?? Personally I don’t call that cold? IMHO a plate has to work at 20c or lower to be cold (room temp), but I don’t make the rules
For next time, give IPA a try. That usually gets TPU off. Just sprinkle it around the edges of the print and it wicks in between and in a few minutes it will be released without mechanical force.
Unless it’s fused, but with most plates even when you think it’s fused, IPA loosens it up without a problem.
I have a lot of use with the cold plate. I really like the fine matte texture of the biqu glacier. If the frostbite was actually smooth it would be nice. The adhesion is nice too. They wear out faster than pei, and on the U1 the magnets mar the bottom of the plate. They also tend to be thinner than the stock plates. A caveat about cold plates though, a coating like the eibos krios is no good.
