AI assistants and sensors are not working
On the 17th attempt, I got the first satisfactory result. There were 3 errors of “finishing the filament”, just in case, I had to completely unload and load it again. Now it remains to figure out the settings of the slicer, which “increases” the gap from the table to the part by 0.2 mm, despite the value of the “vertical gap” of the connecting layer of PLA support from above and below = 0. At the temperature of the table, there is also a separation of the corners of the part from the surface of the table by 0.5-0.8 mm, which makes the coupling of the parts uneven. I ordered 8 more coils of filament :-))) I’ll make it print correctly… Nopassaran!
I also fixed remote access to the printer via the cloud, completely deleting all settings and re-linking the printer to the cloud + re-linked the printer in the slicer via a PIN code.
