I have found the anomaly to be caused by the following procedure
The firmware is the latest version as of today.
Transfer the GCODE file via WIFI.
Start printing on the LCD touch panel.
On the LCD touch panel, Stop printing before it starts.
Start printing the same file on the LCD touch panel.
Printing did not start normally after the above steps.
The temperature of the print bed appeared to be 70/0 and it appeared that the target temperature was not set.
I think there is some kind of bug in the print interruption processing part.
Known bug. Been reported on here several times.
Use 2.9 for most stable.
2.10.0 has the bug that sometimes 3d prints get stuck at 99% even though they are finished.
Take your pick
No.
(at least not any more than ever upgrading the firmware can. There’s always a chance of a power issue or something else causing it to go wrong. I’m not sure if SM is actually doing a firmware upgrade or if it’s more of an operating system upgrade.)
