Adhesion Width change or BRIM does not work
Is there a way that i can reduce the Raft/Brim Width, as it is noticed i can only print with RAFT. Also need to understand why i cannot print with BRIM and when i set this option print does stick to plate.
You may have to use Cura or Simplify3d to reduce the widths
Hi!
You can set the brim and raft width in the SnapmakerJS (CuraEngine) settings. Here is my post about the brim and raft settings:
http://forum.snapmaker.com/t/raft-size-increased-on-js-version-why-how-to-decrease/3512/5?u=schnabsix
Tip: If you go through the fdmprinter.df.json you can find a ton of settings, you can addapt for your printer (e.g. support print speed)
Thanks a ton, it worked…
