About the Snapmaker Luban category
Receive support for Snapmaker Luban. Find a bug? Tell us by reporting it here.
Hello, I am not sure if this is a bug in the software or the printer, but on my last two prints Luban is set with the default PLA settings which should start with the heated bed at 70 degrees for the initial layer, then drop to 50. On both my prints the screen on my snapmaker 2 says that the bed is at 70 degrees for the entire print.
Tried to slice this file. Initially I selected Fast and it sliced fine but it definitely needs support. When I went to customized and enabled supports, then clicked generate, it has been stuck at 100% for an hour.
Hello, I just made a repackage of the luban deb from the beta release thread for Arch Linux.
The package is uploaded to the AUR and can be found at this address, I don’t know if it can be useful to add the link (or the info) to the release thread. I will try my best to keep the AUR package up to date with the releases from this forum
