(Replace this first paragraph with a brief description of your new category. This guidance will appear in the category selection area, so try to keep it below 200 characters.)
Use the following paragraphs for a longer description, or to establish category guidelines or rules:
Why should people use this category? What is it for?
How exactly is this different than the other categories we already have?
What should topics in this category generally contain?
Do we need this category? Can we merge with another category, or subcategory?
              I pulled the most recent code from GitHub and built it locally. Two things: first, when editing materials, I get an error message “Something went wrong. Please reload the app.”  Second, when slicing, I often get an error message “Slicing failed because the model is too small”. The first is a recent change, the second has persisted in all the versions I’ve built from GitHub.
              I was dealing with the 2nd part, “model too small”, found something related to 2.0 and it worked for me.
I basically had to delete every old Luban file from my computer including the beta, then reinstall beta. But to go back and use regular Luban you need to do the same to Luban beta.  As far as i can tell this happens every time between switching between the 2 on my windows 11 pc. Hope this helps
