I’ve looked through other similar topics but can’t see that anyone has specifically mentioned this possibility. The A350 bed only heats up to 80 degrees whilst the A250 goes up to 100 because of the necessary power draw to heat the larger bed. Has anyone explored attaching a A250 bed to a A350 chassis? I believe the power supply is the same so that this would allow a smaller build area but would allow A350 users to heat a smaller bed size up to the 100 degrees needed to print with ABS etc. We’d need a replacement base plate if using the original set up but with the quick swap set up I’m not even sure we’d need that and they’d have to be an option to select an A250 build plate for levelling but am I missing something?
