I saw a recommendation for a 4 Jaw chuck for the rotary module several weeks ago and can’t find it now. Could someone post it?
Thanks
Hi , I know this post is old but did you manage to change the chuck, I want to put a 4 jaw chuck on but I don’t seem to be able to remove the original one, just wondered if you managed and what method you used, I suspect that the threads have had Locktyte applied?
Thanks
Dennis
Yes, I was able to remove the old chuck. It was a long time ago, and I don’t remember there being too much difficulty. I checked it out yesterday and used a thin ¾ inch wench and a pair of channel lock pliers and removed it and installed the 4 jaw chuck just for a test. Snapmaker does tighten things too much on different things. I haven’t used the rotary for 3-4 years.
Thanks Larry, knowing somebody else has managed helped me.
For anybody else swapping chucks be warned, snapmaker use thread lock on the 14mm thread so it takes considerable force to undo it.
