2W laser issue where lightburn stays busy after job finishes
I’m having an issue with the 2W Laser, it engraves fine but once it finishes and goes to home (i added a G28 to the machine settings) it goes back to busy and more G1 and G0s are sent to the laser and it will just stay all the way up and twitch back and forth and Lightburn stays busy. I have to restart Lightburn every time. I’m going to test with a different file once the current job completes. At least it’s all the way up when it does it and doesn’t damage the material.
Thank you for the detailed description of the issue. To help our technical team efficiently troubleshoot the problem, please submit a support ticket through our official support channel
:backhand_index_pointing_right: https://snapmaker.formcrafts.com/support-ticket
Thank you for your cooperation!
Hi, I have the exact same problem.
I’ve already tried all sorts of things. Unfortunately, without success.
What was the solution to the problem?
Best regards, Bernhard
I don’t think I resolved it. I was just stopping the job just as it finished.
Thanks for the reply. I’m temporarily saving my projects with the “go home” command.
It’s not an ideal solution, though. I’ll try submitting a ticket to Snapmaker.
