2nd FIlament Holder Tube
With the 3DP module why is the holder tube, the rod that supports the filament reel, 10mm shorter than the one supplied with the original single nozzle unit?
I ask because a full 1kg reel of filamant could, in theory, fall off!
Regards
Graeme
Have asked myself the same question when I received the unit - no idea. Most 1 kg fit well, but some manufacturers have broader spools. I was in the lucky position that I typically had at least one spool that fitted the shorter rod, so the broader spool went to the longer rod.
After a bit of reluctance, I finally got myself filament dryers, and now print from them, so no longer an issue.
