I am engraving some business cards and when i run boundary, it engraves the material. I have tried anodized and painted aluminum and painted brass and it has done the same thing each time. Is there a way to adjust this?
There is a setting on the touchscreen about the laser strength while setting the work origin, maybe it’s for the boundary too.
This could be set from 1 to 3 percent or so.
But this i read as it only fixes a problem for a non visible laser point in job preparation:
" * In this update, you can use Laser Shot Output Power Settings for fixing the 10W Laser Module which did not show laser indicator in Laser Job Preparation"
