10W Laser calibration target missing
I´ve purchased the 10W Laser for my A350T and it´s missing the calibration TARGET. The calibration card is inside the box.
Can somebody please scan it or provide me the picture to print it on paper.
Or is there another way to calibrate the 10W laser?
Best,
Juan
The calibration target is to calibrate the thickness triangulation. It’s not as important as a picture, but the thickness. Mine is 60x60x2. So if you have an object that is exactly 2mm and over 60mm it should work fine for running calibration.
You can also email support@snapmaker.com and tell them it wasn’t in the box and they should send you one.
Thanks Skreelink.
Would you be so kind and maybe send me a photo of the top view of the card? I thought the laser also uses the graphic as some sort of reference - doesn’t it? Otherwise why is there a target if it´s only for the thickness.
The snapmaker knows the thickness of the target, and the height of the table. So when it calibrates the thickness laser, it can derive values for other objects via triangulation. That’s why the thickness is important. The markings on the target are just general info.
