I’ve been meaning to do some zippo tests, saw a sale on brass zippos, so I snagged a few. The dark engrave is just perfect on them. I’m sad on the first side I centered the text horizontally, but forgot to move it up, but I got everything else right on that side. However, I made sure the second side was 100% correct. I’m covering the top of the second side because it had a personalization for someone.
Jolies gravures, bravo !
J’apprécie vraiment la finesse des gravures avec l’IR.
J’ai pu creuser un peu certaines gravures de médailles inox, ce qui donne un joli effet de relief et c’est sensible au toucher.
Quels paramètres avez-vous utilisés pour ces briquets?
Brass:
0.05mm Interval, 100% Power, 1500mm/min
Steel:
0.05mm Interval, 100% Power, 500mm/min
Merci.
0.05 ![]()
