Z Calibration
Does anybody know how the U1 probes the bed? Force sensing, I presume, but where?
If I’m not mistaken, the U1 doesn’t use a load cell to probe the bed. It uses an inductive sensor integrated into the print head, near the nozzle.
This sensor generates an electromagnetic field that detects the distance to the metal surface of the bed, without needing to touch it. It measures different points and uses that data to calculate the bed mesh.
So it doesn’t detect force when touching the bed, but rather distance changes through electromagnetic induction.
Here’s a picture of a disassembled toolhead, taken when I was changing the hot-end:
I see no sign of an inductive sensor, nor anywhere for an inductive sensor to be. The wires are accounted for as nozzle heating and temperature sensing.
supposedly it’s that copper-marked part
I don’t see how – that’s just a copper plate, something to do with thermal management. Neither is copper magnetic, so it’s not going to form part of a magnetic circuit, and it is a very long way from the probe point.
But… I don’t understand what it is there for so maybe…
I’ve wondered about this as well. Do you still have the hotend off the toolhead? Can you post a picture of where the copper plate would contact the toolhead?
Since it’s copper, I’m inclined to think it’s electrical… maybe when the nozzle touches the plate, it completes a circuit through the plate.
If that’s the one, this system is also used by another printer brand, but in that case it’s pressure-based, but it uses a very similar plate.
Perhaps tomorrow – I’m running a print at the moment. Anybody else?
I did look at the time, but I don’t recall seeing anything the copper plate would make contact with. To be confirmed. However… a circuit through the plate? PEI?? No way.
Pressure AKA force. That’s what I think too, I’m sure the nozzle makes physical contact.
Instead of you all guessing why not just ask @Zoe_M for an official answer? :rofl:
Because that’s how we spend our time, research, and come up with ideas. :rofl:
Because it’s more fun, and anyway if Snapmaker wanted us to know it would be in a specification somewhere!
This is it. The sensor sits where the copper plate meets when the hotend is seated in the machine. It does the filament calibration with this sensor as well.
Bold claim, care to explain?
Not through the PEI… I’m thinking in the toolhead. So when it touches the plate, the copper plate is pushed up and completes some circuit in the toolhead.
Sorry, that’s incorrect. I’m referring to my previous answer. The U1 works like this:
  • The nozzle approaches the bed.
  • When it touches the surface, it exerts a small amount of pressure.
  • The print head’s detection mechanism registers this deformation.
  • The electronics detect the contact and record the Z position.
  • It repeats the process at different points to build the leveling map.
No definitely not. The nozzle assembly is securely bolted to the toolhead chassis, there is nothing that will move.
Agreed.
Sure, but that’s the point: what “detection mechanism”?
Motor current?
It’s all to be found online in the wiki. There’s multiple articles mentioning the sensor. One of the even mentions it’s an inductive sensor.
Anyway, here’s one where they sort of explain where it sits:
Sure, but that doesn’t say how it works. In the U1 extruder unit replacement guide, for disassembly the caption refers to “Calibration sensor cable”, and for re-assembly it’s “Inductive coil cable” (both referring to the same connector). Consistency!
Here are some detailed photos. I didn’t want to pull the toolhead apart any further than this, but I might do in the future – I have some custom filament guides to fit.
What we have is two conductors going to something very thin, shiny, and covered with some kind of woven tape.
I’ve checked the copper-coloured plate at the top of the nozzle assembly, and a magnet does not stick to it, so I guess it must be copper or some alloy of copper. A magnet does not stick to the (black) heat break heatsink, and the copper plate does not touch the nozzle tube. We know the nozzles can be stainless steel, hardened steel, or DLC coated steel, so the mechanism cannot rely on the nozzle having specific magnetic properties (stainless steel is very different magnetically than normal steel).
Hypothesis (ie: not proven)
A thin coil behind the woven tape is used to induce an AC current in the copper plate, and the resulting load in the coil (or perhaps sensing residual currents after drive to the coil is shut off) responds to tiny variations in the gap between the coil and the plate (like a metal detector). The woven tape acts as a compressible separator.
The flexure caused by the nozzle physically contacting the build plate (or anything else) changes the gap, and is detected
This is not the same as an inductive sensor, which senses the location of the print bed (and requires a steel plate as the print bed). It is (effectively) a load cell, sensing force (indirectly).
Experiment to Disprove the Hypothesis
(Hypotheses can only ever be disproven, not proven.) Add a block of wood to the print bed. When the nozzle homes in Z, if the nozzle ignores the block of wood (and causes the motors to stall) it is not using force sensing.
What do you mean “filament calibration”?
Well, I’m not sure what to tell you anymore; one source says it’s pressure-based, while another says it’s induction-based—let’s hope Snapmaker clears things up for us.
