The vertical seam is where the Z axis raises. In Luban, it’s always at the same location, but other slicers have more options to control it.
There’s usually a travel when raising the Z axis. If it was happening every layer the whole way up, I’d say you need to tweak your retraction settings to prevent under extrusion after retraction.
But it’s only happening higher up, since the bottom layers are fine. Are you getting any binding on the filament? I had some issues when the spool started to get near the end that the filament would start binding as the Z axis went up. I first noticed the filament “clicking” as it would bind then release. As it got worse, I could hear the extruder gears grinding because it couldn’t pull the filament. If that’s the case, there are several filament routing / placement options on thingiverse to made your filament feed more easily.
Hi. There is definitely no problem in the filament path. I have a dry box on top of the snapmaker enclosure and an ptfe Tube Right through the housing.
And It really looks like it is on the exact same layer.
I have also printed two versions with the Prusa slicer and got the same behavior on the same spot, next to the seam.
Sure it’s not an issue with the model? I’ve had something like that show up when I thought I had 2 shapes lined up but they were off by .01 mm in Fusion and I didn’t realize it.
Does the model have any shape changes at that height? We can only see one side… Perhaps the slicer is deciding to add retractions at that height and the settings are too aggressive
