What can I do about this typo?
Hi everyone,
I’m generally very happy with the U1, but I keep running into issues with certain round shapes that I don’t experience with other printers.
As you can see, the strands should ideally be part of the structure, but it doesn’t do that. With rectangular prints, there’s no problem, but with smaller, more rounded shapes, it does this.
Which setting could fix this?
I’d appreciate any tips. Thank you very much!
Hello, low speed in curved areas.
This is a problem with adhesion. When the nozzle is drawing inside a curve or an angle, if the extruded material isn’t properly welded to the part, the tension across the span pulls the extruded line away from the rest of the print. This won’t happen on the outside of curves or angles.
There are several routes to a solution:
  1. Increase the print temperature;
  2. Reduce the print speed (in general, or just for outside walls);
  3. Reduce the cooling;
  4. Increase the flow rate percentage.
What is not commonly understood, at least not among the inexperienced, is that 3D printing is not “one size fits all”. You will find there are difficult cases where slicer settings need to be tweaked according to the geometry of what you are trying to print, the filament being used, and what mechanical properties the finished print needs. It is entirely possible that the same print in a different colour would come out just fine.
However, on closer inspection I can see this is specifically a Layer 1 problem, with the adhesion to the print plate. I always have my first layer set really slow (and that’s why slicers have separate settings for Layer 1 than the rest of the build).
Looking at your design, before giving my probable answer, I would like to know: did you add a fillet or a chamfer to the sides of the print?
An unsupported chamfer would be a second-layer problem not a first, but my comments would still apply.
Thanks so far.
I set the print speed to 20 mm/s for the first 5 layers, but unfortunately, that didn’t prevent the error either.
I haven’t experimented with temperature, cooling, and flow rate yet, as I’m still relatively new to this field.
Go down to 10, but only for the first layer.
