I have read and understood all rules of the Innovation Fund Phase 2
on
I consent to my project information (username, project cover, summary, etc.) being publicly displayed for review and showcase
on
Username (for public display)
dlvkz
Project name
U1 Scan Studio
Project URL
https://github.com/dlvkz/u1-scan-studio
Project cover
Project Category
Software
Project Summary
U1 Scan Studio turns the Snapmaker U1 into a 3D scanner, using only the printer itself. A turntable is printed once. After that, any object up to 19 cm across can be put on the disc, and be scanned in about 30 minutes. The result is a printable, textured 3D model (STL / OBJ / PLY, or a 4-color 3MF).
No motor, no electronics. Every part of the scanner is the U1:
- The U1’s built-in chamber camera takes every photo. A calibrated model of it gives each photo’s exact view.
- The toolhead turns the turntable. A cold nozzle dips into one of 24 pockets on the disc’s rim and pushes it 15° along.
- The bed moves through 7 heights at each of 12 angles, so the fixed camera sees the object from all sides and from above.
- The turntable parts can be printed from the setup wizard, with the toolheads to use picked there.
A dense ArUco marker pattern on the disc gives its exact angle and position in every photo, so nothing needs precise placing. A recording of the empty disc separates the object from the background. A neural surface (NeuS-style signed-distance field, written for this project) is trained on the GPU from all photos, refines the views’ positions, and gives a closed mesh colored from the photos.
Safety is built around the U1’s real geometry:
- The app measures the object’s height with the camera before scanning.
- Before every stroke it checks, using the measured outline of the toolhead, that its path is empty in the photos so far.
- It won’t home with something on the disc, because homing presses the nozzle on the disc center.
It is a complete app for Windows and Linux:
- a setup wizard (connect, print, install, record the background)
- a guided scan page with live camera and checks
- a model viewer, downloads, and export/import of scans
- Open in Orca: the model’s colors as up to 4 filaments, in a U1 project for Snapmaker Orca, to print a 4 color “replica”
It works on stock firmware and on the extended U1 firmware by paxx12. On the extended firmware it adds live video, exposure brackets for shiny objects and, with SSH on, sweeps recorded on the printer itself, which makes recording each sweep about 65% faster. Model building runs on NVIDIA cards (tested down to 4 GB): about 15 minutes on an RTX 3080 Ti, 22 minutes on a 4 GB RTX 3050 Mobile.
Tested on a Snapmaker U1 from a Windows desktop and a Fedora laptop. Transparent and very thin objects are the known weak spots, while opaque and rigid objects work best.
Open Source Status
Open Source
Please specify the open source license used by this project
GPL-3.0
Cash Fund or U1 Hardware Sponsorship
Cash Fund
Originality
Original New Idea
If based on an existing project — your independent contribution
N/A. The idea, the turntable design, the scanning and tracking code, the safety checks, the reconstruction and the app are all written for this project. Open-source libraries are used as dependencies (OpenCV, PyTorch, trimesh, PyMeshLab, three.js and others, credited in the README). The surface reconstruction follows the published NeuS method (Wang et al., 2021), implemented from scratch here.
Is it a paid project?
No
