U1 Filament RFID Tags & Custom Spool Holder Discussion
Its the same when I had BL machines, I used sunlu, flashforge etc etc on it… I personally can’t see them all agreeing as they all want people to but their filaments & close systems make that easier for them to justify why you should only buy it from them.
I hope it doesn’t go down the chip route like printer carts have
Could you give me some advice which tags to use? Maybe you have a link available?
KInd regards,
Peter
The tag is on the back of the colour swatch I print for each filament I use
Technical info here: RFID Format & Reader Design - Custom Snapmaker U1 Firmware
Great idea!
But you are not using the default spool holders?
Kind regards,
Peter
Yes that’s the “fun” of modding the machine, change one thing have to alter 3 others :joy:
No, he’s feeding from dry boxes.
Currently yes, but I think I’ll print 4 of these in PETG and try to see how they perform as they’ll allow me to still use my rfid tags
A couple of comments:
What if the spool already has an RFID tag – wouldn’t that interfere with your swatch (or would you just not have a tag on that particular swatch)?
Why hasn’t this design moved the roller up, so that the spool occupies more-or-less the same space as the standard holder would?
Only the BL filament I use has tags, I don’t /believe/ that Openspool reads those, but its easy enough to cut off before loading into a reel with refills
Er, pass? I printed one in PLA to see how it looks:
I still like the idea of the 4 x S1’s on top - but this way would save me having to buy another 3 @ £75…
