đź’ˇ Tutorial: Turn Your Snapmaker U1 into a Dedicated Filament Dryer (Firmware Bypass)
Snapmaker officially recommends using the heated bed and a ventilated cardboard box to dry filament. However, if you try to run a raw G4 timer script via USB to keep the bed hot, the U1’s firmware blocks it with a “Please Select Filament” error.
Here is the “Slicer Hijack” workaround to bypass the multi-toolhead gatekeeper and safely run drying cycles on the U1:
The Setup (One-Time):
  1. In SnOrca, clone your U1 printer profile and name it “U1 - Filament Dryer”.
  2. Delete everything in the Machine end G-code box so it is completely empty.
  3. Replace everything in the Machine start G-code box with this exact script:
Plaintext
M140 S65 ; Heat bed to 65C (Change for different filaments)
M190 S65 ; Wait for bed to reach target
M104 S0 ; Keep nozzle cold
M106 S0 ; Keep part fan off
G4 P21600000 ; Dwell for 6 hours in milliseconds (Change as needed)
M140 S0 ; Turn off bed heater
M84 ; Disable stepper motors
M2 ; Terminate print job immediately
How to Use It:
  1. Place your wet spool on the heated bed. (Pro-tip: Elevate the spool on four small printed cubes to protect the plastic flanges from direct conductive heat and allow airflow).
  2. Cover the spool with a cardboard box (I used the box that had contained the 4 spools) that has a few small ventilation holes poked in the top.
  3. In your new SnOrca dryer profile, add a dummy shape (like a Voron cube) to the build plate.
  4. The Trick: Assign the dummy cube to a filament profile that is currently loaded on your U1.
  5. Slice and export to your USB drive.
When you run this file on the U1, the firmware sees a valid toolhead match, allows the job to start, runs your thermal timer, and immediately terminates the print safely via the M2 command before the toolhead ever moves!
Just found another method from Rodrigo Sclosa
