I down loaded the new version of Luban and was unable to get any drop downs on the right side so I did as recommended and uninstall and reloaded 3.12 version that was originally loaded and now I have the same issue with the program is not loading correctly. I am far from any type of computer expert can some one point me in the right direction. I am completely frustrated.
Restart your pc between uninstall and new install.
Hope this helps!
Tried that a few times. Beginning to wonder if it is a setting with my laptop
Hi, there is a very small ‘<’ sign on the right side. This toggles the dropdown menu.
All others dont have this.
Problem is I can’t slice or generate a G code without the drop down menu.
Did you load an .stl file ? Your screenshot does not show a model that has been loaded.
When a model has been loaded more options appear in the right handside column.
See the attached image. I have loaded a model and right at the bottom is the generate gcode.
Tip: If you need to send a screenshot use Alt-Windows-PrtSc which will capture the active window to clipboard. Paste it using Ctrl-V.
Thanks for the screen shot tip. I load a project and see what happens will let you know
Do you have a snapmaker original?
Because that’s what your Luban is showing.
Click on “original” to select your model.
Yes SnapMaker Original
I had the same thing happen to me. I’m not sure how I fixed it, but I think it was File>New.
