OK, I see you want to push to the maximum.
At this point, you have to start a bit smaller and easier.
Try to print it with 0.12 Layer height (or a other multiple of 0.4mm, search for magic number if you are interested) and see if you want to push further.
I don’t want suggest you to calibrate your machine after the first print. - It would be good, but normally beginners don’t need to.
Anyway your walls are pretty slow, you don’t need to print that slow, 20mm/s would be ok for this details I guess.
I would suggest to have a look at this:
