Hi folks…Looking for a storage box file. I saw a post about a storage box for under the A350, can’t find it on Facebook either. Can anyone direct me to it? Or if anyone has any other ideas. Looking to design my own in the near future,
I made a laser cut one from 1.5mm ply using the Fusion 360 parametric model in this video. It means you can set the size and add the dividers to match what you want.
The box I made was 250x110x40mm to fit under the centre area in the 350.
I Didn’t use the method detailed to create the DXF output though, I created sketches for each surface and exported as DXF and imported into Lightburn to do the sheet layout for lasering.
