I am trying to import an STL model for a CNC relief carving. The STL preview looks fine, but when I generate in gcode and preview the simulation, it shows strange streaky lines. See image below. Any idea what causes this or how to fix it? Or, will it actually carve those lines or is it just a visualization error?
Luban is prone to visualization bugs. Double-checking the gcode with a third-party visualizer like NC Viewer should allow you to figure out if that’s the case here.
Hi i am having a similar issue but when i generate the g code i loose my original image all togther and just have the lines
