Standard 1.6 Laser cuts some white paper but not all white
Would anyone know why my A350T with fitted standard 1.6 laser will cut white a4 printer paper but wont cut white wrapping paper
I’ve read that white paper can be tricky - if it reflects too well, not enough laser energy is absorbed, and it does not cut. All I tried worked well, but YMMV.
Things you might try is going slower, or if not already there, increase to max laser intensity.
Finally, if it is wrapping paper and you cut from the back: Blacken the paper - e.g. with a sharpie or so (not sure if that is a practical solution in your case…)
Thankyou, have a co2 laser as well - different machine and this was first time using a diode laser, was unaware of its limitations
