Softwere Problems with the Luban
i can’t print with a support is it a buck in the Softwere or were is the Problem?
i have Installed the last version of Luban
Ok But can you invate me to Kreate a Customer profile at the softweare Luben
You will need to create a custom profile to be able turn support on.
Select a built in profile close to what you want and then click Customize followed by the ‘+’ sign underneath. You can the change all the settings without affecting the default profiles.
