Software can't retrieve color assignments
Go through loading procedure, define filaments and colors of each toolhead. Snorca can’t see them . Often has multiple colors assigned to the same tool head.
Searched before posting. Widespread issue.
Wasn’t this answered in a previous thread of yours? Does the U1 ignore Snorca filament assignments? - #6 by SpyderByte
Also, from https://forum.snapmaker.com/t/snapmaker-orca-app-v2-3-5-beta-test-join-in/42470:
  1. Added a filament sync feature. You can sync filament information from the printer to Orca using “Match Mapping” or “Direct Override”.
As a general comment: the first post in forum thread should stand alone, containing enough information that somebody not already aware of the details can understand what you’re talking about. If it is describing a problem you want help with, you should describe how to reproduce the problem (reliably).
Otherwise, just a brief interjection without explanation comes over as a complaint without substantiation, then you get criticised for it and get the impression the forum is a “shark tank”.
