I have just installed snorca for the first time. Connecting to the SM2 is not straight forward as it won’t find the device and I have just worked out how to add my IP address (which it doesn’t save for some reason) so I have to add it every time I open the program.
Anyway, when I go to select the filament, the generic and breakway do not show. It only shows polylight and snapmaker. I’ve tried searching everywhere on how to overcome this but have not found anything. Has anyone encountered this problem and been able to resole it. Thanks.
Can you be more specific? What tab are you on – the Prepare tab? A screenshot would help people see the context.
I don’t know whether this will turn out to be relevant, but setting up SnOrca you get to choose the range of filament you can select from on Prepare. You can get to that menu from the little settings icon alongside “Filament Management” down the left panel:
Sorry, I have included some screenshots. In the drop down in the prepare screen, I only get polylight and snapmaker. I have included all filaments as you can see from the other screenshot.
I wonder if it’s because you have everything in every section ticked? Might be worth taking 5 minutes to remove what you don’t have/use & see if it appears then?
As maybe it has a limit to how many can be shown at one time?
ColdCoffee: I wonder if it’s because you have everything in every section ticked? Might be worth taking 5 minutes to remove what you don’t have/use & see if it appears then?
I am not sure if this is your issue, but I was having the same issue and then realized that after a Snorca update, it was defaulted to a 0.2 mm nozzle instead of the 0.4 I have installed. Changed that and all was back to normal!
