Snapmaker & V-Carve
Hi, I was wondering if anyone had experience with V-Carve and the CNC functions of Snapmaker and would be able to answer some questions.
I have just started using it and this morning ran into an issue with my first project when the initial part of the project worked fine but then it just moved off the stock and started cutting thin air. I had checked on the simulation multiple times and it showed it should have cut it correctly. I checked I had set everything up right and made sure the correct Post Processor was used.
Has anyone experienced this problem before using V-Carve?
Thanks
Paul
