I am using the latest Snapmaker Orca slicer, 2.4.0, and set up PLA for toolhead1 and PVA for toolhead2. I set PVA for the support interface only and Default for the base. The preview shows PVA being used for the entire support and printing the model is using PVA for the entire support. What am I missing?
Hi, can you also share me the .3mf file?
(The forum didn’t allow uploading the 3mf file format directly.You could try to upload a zip folder or cloud drive link)
It is also suggested to test whether the 2.4.1 beta version helps:
Wait for your reply.
Best regards.
Here’s the 3mf file I used.
trio_Eris-Roxy-Sylphi.zip (8.0 MB)
Hi, please refer to
Best regards.
Never mind. After clicking on the line right under Plate 1, the Support tab appeared. After changing the settings and slicing it, it showed what I expected. Thanks for leading me to the solution.
