Snapmaker Orca V2.4.1 Beta Release
Hi everyone,
Snapmaker Orca V2.4.1 BetaTest is ready for testers. This Beta build adds uninstall cache control for Windows, prime tower toolpath improvements, new support & multi-filament validation warnings, plus new acceleration/jerk and paint penetration parameters.
Download Link & Release Notes:
Release Snapmaker Orca V2.4.1-Beta-Release · Snapmaker/OrcaSlicer · GitHub
Snapmaker Orca V2.4.1_Official release:
Releases · Snapmaker/OrcaSlicer · GitHub
New Features
  1. Added a cache clearing option during uninstallation (Windows only). You can choose whether to delete personal data during uninstallation; unchecked by default.
  2. Added a feature where the extruder detours around the Prime Tower and enters through the outer wall opening during tool changes.
  3. Added four parameters to the Filament panel: Interface Layer Pre-extrusion Distance, Interface Layer Pre-extrusion Length, Interface Layer Print Temperature, and Adhesiveness Category (visible in Developer mode).
  4. Added two parameters to the Prime Tower panel: Enable Tower Interface Features and Cool Down from Interface Boost During Prime Tower (visible in Developer mode).
  5. Added one parameter to the Prime Tower panel: Internal Ribs (visible in Advanced mode).
  6. Added a tree Support Transition type with independent print speed and flow settings to improve support print quality.
  7. Added a support parameter validation prompt: when the support style is “Organic” and the base pattern is set to “Lightning”, a pop-up warning will state that the “Lightning base pattern is not supported and Rectilinear will be used instead.”
  8. Added a support parameter validation prompt: when the support style is “Organic”, Support Wall Loops is set to 2, and the base pattern is non-default/hollow, a pop-up warning will appear.
  9. Added the “Minimum Support Contact Area” parameter, which allows you to set an area threshold to determine whether a support interface is generated.
  10. Added multi-filament support detection: when “Support/Raft base” is set to a non-soluble material, a pop-up warning appears and allows you to reset it to “Default.”
  11. Added multi-filament support detection: when PLA/PETG are used as support for each other and the Base pattern or Interface pattern is non-default, a pop-up prompts you to reset the parameters.
  12. Added “First Layer Travel” parameter under the Acceleration section; added “First Layer Travel” parameter under the Jerk (XY) section.
  13. Added the “Top/Bottom Paint Penetration Layers” parameter: configures how many layers the painted top/bottom areas penetrate into the infill, solving color bleeding when mixing light and dark filaments.
  14. Added multiple new colors for Snapmaker PETG HF filament.
Improvements
  1. Optimized the prime tower logic. Filaments are now automatically grouped by adhesion type, preventing mixing of materials with different adhesion properties and improving wiping tower stability.
  2. Optimized prime tower preview on the Prepare page: pre-slicing size of prime tower now closer to actual result; post-slicing shape matches the sliced result.
  3. Changed the default wiping tower position from top-left to left-center.
  4. Moved the “No Sparse Layer” option to be visible only in Developer mode.
  5. Changed the default value of “First Layer Expansion” to -1 (Auto), with support for 0 (disable expansion) or ≥ 1 (expand outward).
    Note: When opening a 3MF file created in V2.4.1 with an older version of Snapmaker Orca, an error prompt will appear as follows.
  6. Changed the minimum support threshold angle to 1°.
  7. Changed the “Bridge Flow” default value from 0.8 to 1.0, and “External Bridge Density” default from 80 to 100.
  8. Changed the “Max Bridge Length” default value from 10 mm to 0 mm, so bridge areas get full support by default.
  9. Raised the “External Bridge Density” upper limit to 120% to improve bridge surface seam closure.
  10. Optimized filament display on the Prepare page: changed from a dropdown to a hierarchical menu for faster search and selection.
  11. Optimized the pop-up logic for High Flow Hot Ends: removed the unclear hover pop-up; now, when a high-flow hot end is detected, the filament grouping window pops up by default during slicing.
  12. Optimized the G-code template to prevent nozzle collisions with the object during sequential printing, filament changes, or print pauses. Thanks to Kuzuri ( KuzuriAo (Kuzuri) · GitHub ) for the contribution. Related PR: Fix "Print by Object" collisions by KuzuriAo · Pull Request #453 · Snapmaker/OrcaSlicer · GitHub
  13. Optimized the pop-up message for sequential printing collision risk.
  14. Optimized G-code preview rendering performance, improving responsiveness of interactions such as layer-height replay.
  15. Optimized graphics rendering performance, reducing context switching frequency and improving UI smoothness.
  16. Optimized model selection highlighting.
  17. Optimized loading efficiency and some UI text on the Home, Preview and Device pages.
  18. Optimized the user experience for software login and device connection.
  19. Optimized the bed temperature parameters for multiple filaments.
Bug Fixes
  1. Fixed an issue where exported 3MF files contained Bambu brand fields; these have now been replaced with Snapmaker_orca brand fields.
  2. Fixed an issue in V2.4.0 where modifying the “Small part” parameter under Process > Object > Speed displayed an invalid error.
  3. Fixed an issue in V2.4.0 where Bambu Lab 3MF files failed to parse after modifying object speed values and importing them into Orca.
  4. Fixed an issue where filament colors were displayed incorrectly in the statistics list on the Preview page when opening a G-code file in Orca.
  5. Fixed an issue where the interface displayed a Textured PEI Plate, but the actual plate was a low-temperature cold steel plate.
  6. Fixed an issue where colors could be missing when using filaments with IDs greater than 16.
  7. Fixed an issue where the Prime Tower preview size on the Prepare page changed with the total number of filaments.
  8. Fixed an issue where the model’s first layer was incorrectly subdivided after enabling “Subdivide Mixing Layers.”
  9. Fixed an issue where unused filaments were still displayed in the Prime Tower on the Prepare page.
  10. Fixed an issue where the outer wall opening parameter was still displayed after disabling the Prime Tower. The “Brim chamfer” and “Max chamfer width” parameters have also been removed from the Prime Tower panel.
  11. Fixed an issue where gaps appeared when the “Wipe tower purge lines spacing” was set to a value other than 100%. The first layer purge lines spacing will now be executed at 100% to improve Prime Tower stability.
  12. Fixed an issue where, during multi-plate multi-color printing, using Ctrl+Z to undo restored the Prime Towers of all plates except the first plate to their initial positions.
  13. Fixed an issue where the model skirt path overlapped with the Prime Tower skirt path.
  14. Fixed an issue where, for special models, elephant foot compensation caused the first layer to be missing after slicing.
  15. Fixed an issue where the “Avoid interface filament for base” option under filament for supports did not take effect.
  16. Fixed an issue where the first layer did not follow the “Inner/Outer/Inner” wall printing order.
  17. Fixed an issue where the actual effect of the support interface pattern conflicted with the “Default” setting.
  18. Fixed an issue where the infill pattern did not meet expectations when sparse infill density was set to 100%. A prompt will now appear.
  19. Fixed an issue where the cooling fan caused an abnormal drop in Z-axis height.
  20. Fixed an issue where Pressure Advance still took effect after being disabled.
  21. Fixed an issue where gap fill was printed before outer walls.
  22. Fixed an issue where Boolean operations failed when some objects were mirrored.
  23. Fixed an issue where the “Lock rotation” parameter for embossed text did not take effect.
  24. Fixed an issue where the merge target was lost or pointed to the wrong filament when merging physical filaments into mixed filaments.
  25. Fixed an issue where object-level extruder and filament mapping was incorrect after deleting filament.
  26. Fixed an issue where the object list and layer height range were not refreshed after batch-cleaning unused filaments.
  27. Fixed an issue where the slicing status was not reset after all slicing was completed.
  28. Fixed an issue where the software crashed on startup when the TLS certificate override environment variable was not set.
  29. Fixed an issue where the build plate origin was not initialized, causing abnormal slicing coordinates.
  30. Fixed an issue where, after disabling the GPU on Windows, opening Orca displayed a pop-up and the Prepare page was unavailable.
  31. Fixed an issue where the camera fit shortcut Z did not work on Linux.
  32. Fixed an issue where, in multi-plate scenarios, deleting the plate being sliced during slicing caused the program to crash.
  33. Fixed an issue where the bed temperature in the G-code did not match the bed temperature configured in the Filaments settings.
  34. Fixed an issue where, with multiple objects using different filaments, setting the Skirt type to “Per Object” only took effect for one object.
  35. Fixed an issue where the “Max bridge length” parameter did not correctly show/hide based on “Support type” and its value did not take effect.
  36. Fixed an issue where sliced G-code still had gaps when “External bridge density” was set above 100%.
  37. Fixed an issue where Brim was lost for multi-color models when using painted Brim with “Subdivide Mixing Layers” and “Full Domain” enabled.
  38. Fixed an issue where non-SEMM Prime Towers did not support per-filament minimum purge amount. You can now configure the minimum purge amount separately in Filaments settings and on the Prime Tower page and the larger value will be used.
  39. Fixed an issue where colors were lost or bled after slicing multi-color 3MF files.
  40. Fixed an issue where the slow printing layer count was offset when using a Raft.
  41. Fixed slicing issues such as extrusion path interference and missing tree supports.
  42. Fixed an issue where support interfaces for certain model features could not form a continuous surface. Bambu Lab’s overhang classification system has been introduced.
  43. Fixed an issue where abnormal mapping between Organic Tree support and Raft caused empty layers in long pillars.
  44. Fixed an issue where the contact area of normal supports was lost in Variable Layer Height mode.
  45. Fixed an issue where overhang layers were missing in the Preview page after slicing when “Partially Bridged” was selected for “Bridging Counterbore Holes.”
  46. Fixed an issue where flat models (top height = 0) could not generate supports properly.
  47. Fixed an issue where negative parts of some objects were lost after combining multiple objects and then splitting them.
  48. Fixed an issue where the first layer was missing after rotating a cube 45°.
  49. Fixed an issue where, after enabling Raft, performing Variable Layer Height operations on the model, clicking “Adaptive” and then “Smooth Model” reset the layer height; fixed an issue where selecting “Organic” without enabling supports incorrectly displayed “Variable Layer Height not supported”.
  50. Fixed an issue where Orca did not recognize that one of multiple objects in a 3MF file had Variable Layer Height set.
  51. Fixed an issue where connection status was out of sync in multi-process LAN mode.
  52. Fixed an issue where Linux users’ login status could not be saved.
  53. Fixed an issue where, after repeatedly clicking to download a time-lapse file, the status remained stuck at “Waiting for device upload”.
If you are interested in this build, feel free to join the discussion and leave your feedback below.
I just tried the V2.4.1 beta to see if it fixed the problem of not using the filaments selected for supports. I set the following settings
It’s supposed to use the default filament for the base (in my case it’s PLA) and PVA only for the interface. In V2.4.0, the preview showed this
As seen in the pic, the PVA support filament (I chose reddish to make it stand out) is used for the entire support and there’s nothing on the prime tower (at least nothing visible, it’s all internal) and in the beta, it showed this
The PVA support material is still being used for the entire support and is also showing up a lot more in the prime tower. There is a lot less supports but it looks like they start on different parts of the model.
I’ve included the 3mf file I used.
trio_Eris-Roxy-Sylphy.zip (8.0 MB)
@SGOne
Hi, the engineer helped me check the .3mf file.
Support settings for the Object override Global settings.
The default support settings of your .3mf file under Objectare setting both Support Base and Interface as PVA.
Update:
Hi All,
Snapmaker Orca V2.4.1 now is officially released:
V2.4.1 | Snapmaker Wiki
Best regards.
Snapmaker Installation 2.4.1 zeigt Virus
Thanks for your feedback. We’ve received several similar reports across other community channels. Our engineering team is investigating this issue now. I’ll post an update here as soon as we have more information.
Update:
Here are the latest updates and solutions for the Windows Defender virus alert:
Update on Snapmaker Orca V2.4.1 Windows Security Warnings
Hi @Zoe_M and Snapmaker Development Team,
I would like to bring your attention to a possible regression introduced in Snapmaker Orca 2.4.1 that I discovered while printing with my Snapmaker U1.
After upgrading to 2.4.1, the nozzle repeatedly scratched the top surface of multicolor prints during the final movement toward the prime tower.
I performed extensive troubleshooting and found something important:
  • Snapmaker Orca 2.4.1: The nozzle scratches the printed surface during the final toolchange.
  • Snapmaker Orca 2.4.0: The exact same model prints successfully without scratching.
I also compared the generated G-code from both versions.
In 2.4.0, an explicit Z lift of approximately 0.40 mm is generated before the final movement toward the prime tower.
In 2.4.1, the corresponding final movement appears to occur without that explicit Z lift.
I reproduced this difference using the default Snapmaker U1 profiles and fresh projects.
Since the 2.4.1 release notes mention changes to prime tower travel paths and toolchange collision prevention, I suspect this may be related to those modifications.
I have documented the issue in detail, including G-code comparisons, photographs, and physical printing results:
I have also submitted an official support ticket.
Could the development team please investigate this behavior?
I have temporarily reverted to 2.4.0 because it completed the same print without the final nozzle scratch.
Thank you for your assistance!
Hi, thanks for the feedback. I’ve added some notes to this ticket and left a message for the technical support engineer. I’ll post an update here as soon as there is any progress.
@Zoe_M, a pointer for the engineer on this ticket. I traced it in the source and filed it on GitHub with the lines and a proposed change: 2.4.1: no Z-hop before the final purge, the nozzle crosses the finished top layer · Issue #1149 · Snapmaker/OrcaSlicer · GitHub
Short version: WipeTowerIntegration::append_tcr2() in GCode.cpp changed in b626b4be6 (#937). The 2.4.0 condition should_travel_to_tower || m_need_change_layer_lift_z became !tcr.priming && (tcr.is_finish_first || will_go_down), and the final purge meets neither. Normal tool changes still lift through [change_filament_gcode], which the final purge does not write, so only the last travel to the tower crosses the finished top layer. That is the 0.40 mm lift pipewrx found missing.
Until a fix ships, U1 owners on 2.4.1 can add that one Z-hop with a post-processing script that changes nothing else in the file. It is checked against the U1 firmware in a dry run, not yet on a printed part: u1-dryrun/tools/lift_final_purge.py at main · DesignMaster-Solutions/u1-dryrun · GitHub
The proposed change is building in a fork now. I will add the before and after G-code to the issue when it finishes.
Snapmaker Orca 2.4.1 – Serious printing issues on ALL FIVE of my U1 printers!
I have five Snapmaker U1 printers, and ALL FIVE started producing severely damaged multicolor prints after updating to Snapmaker Orca 2.4.1.
The toolheads appear to collide with already printed objects when moving to the prime tower. The prime towers are damaged, and the prints are covered in blobs, unwanted filament strands, and other defects.
These same models printed perfectly before the update.
Photos of the failed prints:
My question to Snapmaker is simple: WHY is version 2.4.1 still available for download?
This problem has already been reported by other users. Why isn’t there at least a clear warning on the download page? Why not temporarily withdraw this version until the issue is fixed?
People are wasting filament, electricity, printing time, and money because of this.
And one more question about the new highlighting effect:
Is there ANY way to disable the bright white glow/outline that appears around a model when it is selected?
I find this new highlighting effect extremely annoying. In some situations, it seriously interferes with working on models and makes it difficult to see certain details.
Is there an option to turn it off that I haven’t found?
Or am I seriously going to need a separate laptop running an older version of Snapmaker Orca just to work without this effect?
I don’t understand why such a visual change was introduced without giving users the option to disable it.
Please address these issues and give users the choice to keep a clean, functional interface. Reliability should come before unnecessary visual effects.
@Mr.Borispol, I am not Snapmaker, just a developer who traced part of this in the slicer source, so here is what may help today.
Going back. 2.4.0 is still on the releases page: Release Snapmaker Orca V2.4.0 Release · Snapmaker/OrcaSlicer · GitHub. pipewrx found that the same model prints clean there and scratches on 2.4.1 (post 7 above).
What is confirmed so far is narrower than your photos. In 2.4.1 the travel to the tower for the final purge lost its Z lift (post 9 above, issue #1149), and Zoe_M wrote in the other thread that engineering will fix it in the next version. That is one move at the end of the print. Your towers are torn along their whole height, so there is probably more going on than that one move, and nobody has pinned it to a line of G-code yet.
One sliced file would do that. If you can share a .gcode or .gcode.3mf from one of the failed plates, I can run it through the U1 firmware code offline and list every travel that crosses already printed material, with the G-code line and the height. Then the engineers get exact lines instead of photos. A link here works, or you can drag the file into this form and a bot answers in about 5 minutes (the file becomes public there, so only what you can share).
I do not know of a switch for the selection glow, so I will leave that one to Snapmaker.
Thanks for looking into this and offering to help!
I’ve exported the G-code, but honestly, I just don’t have the time to spend on further troubleshooting and investigations.
Of course, after seeing the results of the first prints on all five of my U1 printers, I immediately rolled back to version 2.4.0 — with a LOT of swearing along the way!
What I still cannot understand is WHY THE HELL is version 2.4.1 STILL available for download?
Seriously, what’s going on here? Am I the only one experiencing these problems? Is everyone else printing perfectly fine with 2.4.1?
In my opinion, this version should have been withdrawn immediately until these issues are fixed. Why let more people waste filament, time, electricity, and money?
However, I did notice something that might help:
The problem seems to depend on the position of the prime tower relative to the models.
When the prime tower is positioned on the left or right side of the build plate, the models that lie directly along its travel path get damaged, as you can clearly see in my photos.
But when the tower is positioned so that its travel path doesn’t cross any models, printing seems to work normally.
It really looks like the toolheads are traveling straight through printed objects on their way to the prime tower.
That’s simply what I’ve observed. I hope this information helps.
And thanks again for taking the time to investigate this!
Because it’s a beta, for community review?
If you are risk averse, never try a beta.
I fully understand that beta versions come with risks, and I accepted those risks when I downloaded it.
What I don’t understand is why this version has remained available for so long without a fix for such a serious issue.
Or at the very least, why not put a clear warning on the download page so people know about this major problem before installing it?
That’s all I’m asking for.
@Mr.Borispol, thank you, the file was enough. Here is what is in it, with line numbers, so nobody has to guess from photos.
The plate has 27 bunnies, 229 layers and 187 tool changes. Every trip to the prime tower and back, 372 of them, is one straight line across the plate at exactly 0.40 mm above the layer being printed. Example, line 73306: from the tower at X259 Y255 straight to X27 Y51, about 308 mm, over the other bunnies. So what you saw is what the file says: the heads fly straight over the models that sit between them and the tower. In the G-code they pass 0.4 mm above them, not through them, and this profile does not route around parts (reduce_crossing_wall = 0, z_hop = 0.4).
I ran the first 31 layers through the U1 firmware code, 2.0.0 and 2.1.0. The firmware accepts them and adds no lower move of its own. The whole 22 hour file was too big for my tool’s memory, so for layers 32 to 229 I only measured the tower travels with a script.
Two things for the engineers:
  1. Line 8829545, the last tool change: G1 X236.415 Y231.757 from X56.4 Y244.0 at Z45.85, the print height, with no lift and before the retraction on line 8829556. That is the final purge travel from #1149, 180 mm long in this file.
  2. 0.4 mm of clearance on a 300 mm straight travel over 26 other parts leaves no room for anything that sticks up: a curled edge, a blob, a string from the arriving head. I cannot tell from one file whether 2.4.0 lifted higher or took another path on this same plate. A 2.4.0 slice of the same project would answer that in a minute, if anyone has one.
What I cannot say is which of these marked your prints. The file shows the paths, not the plastic.
Until a fix is out, your own finding is the safest one: put the tower where the trip to it does not cross a model. A larger Z hop should also widen that 0.4 mm, but I have not tested it on a printer.
@Mr.Borispol, I have to correct my last post, and you were right. Your heads do go through the models on the way to the tower.
The 0.40 mm I wrote about comes from reading the G-code as text. This time I ran your whole 22 hour file through the U1 firmware code, which knows where each head really is after a tool change, and that shows something the text hides.
What happens on your plate: the tower is at the right back corner. In 94 of the 187 tool changes, the slicer lowers the new head to the layer height right after picking it up, while it is still at its dock exit (X43.5, X94.2 or X161.7 at Y250), and only then sends it to the tower in a straight line. 74 of those trips pass over your bunnies at the height of the layer just printed. In 52 of them the nozzle touches what that layer has already printed for 5.0 to 40.5 mm, from Z0.45 up to Z42.85. In the other 22 the contact is shorter than 5 mm. The list starts at line 130636, Z0.45. (Edited: I first wrote “24 to 133 mm each”. That is the length of the path over the models, and most of it runs over earlier layers, below the nozzle.) The other 92 tool changes go to the tower first and lower Z there, which is why only some models get hit.
Why it depends on the tower position: 2.4.1 added a detour that takes the head around the tower before it lowers. On your plate that detour would pass just outside the right edge of the bed (X270.9 on a bed that ends at 270.5), so the slicer drops it, but still acts as if the head had arrived at the tower. On 2.4.0 this detour did not exist.
Full list of the 74 lines: u1-dryrun/docs/orca-2.4.1-dock-travel.md at main · DesignMaster-Solutions/u1-dryrun · GitHub
Reported to Snapmaker with the cause in the code: 2.4.1: tower near the right bed edge, the new head drops to layer height at the dock and crosses the plate · Issue #1168 · Snapmaker/OrcaSlicer · GitHub
Until it is fixed, staying on 2.4.0 is the safe choice. If you need 2.4.1, keep the tower at least about 10 mm away from the left and right edges of the bed (on this plate, X around 220 instead of 230.9). That follows from the code; I have not sliced or printed it to confirm.
Thank you so much for taking the time to investigate this so thoroughly and actually finding the cause of the problem! I really appreciate your effort.
It’s great that there are people like you in the community who have the knowledge, patience, and time to dig into these issues.
I personally barely managed to find enough time just to report the problem. I was hoping it would be fixed much sooner, but judging by how long this version has remained available without a fix or even a warning, it almost feels like nobody is particularly concerned about it.
Maybe most affected users simply rolled back to 2.4.0, as I did, and carried on printing. I honestly don’t know.
Anyway, I’m really glad you took this seriously and managed to identify the actual cause. Hopefully Snapmaker will now address it quickly.
Thanks again for your incredible work!
@Mr.Borispol, glad it helped, and your file plus your note about the tower position did most of the work. Without them I would still be looking at the wrong move.
You are not the only one; it just takes a plate with the tower near the edge to show up, so many people never hit it. Both issues (#1149 and #1168) are still open with no reply yet. I will post here as soon as Snapmaker answers or a fixed build is out, so you know when it is safe to leave 2.4.0.
Hi, thank you very much for the feedback.
Could you share the .3mf files of your prints with me, especially the one where the nozzle collides with the model?
There is one more feedback about the prime tower strings:
@Zoe_M, the 22 hour plate is @Mr.Borispol’s and I only have the G-code he shared in post 12, not his project. So I made a small project that shows the same collision, in case it saves the engineers time while his file is on the way:
https://github.com/DesignMaster-Solutions/u1-dryrun/raw/main/examples/tower-right-edge-orca-2.4.1.3mf
It is a two-colour sign, 15 layers, default U1 0.20 mm profile, two Snapmaker PLA, prime tower at X236.5 Y100. Sliced with 2.4.1, 8 of the 15 tool changes lower the new head at the dock right after T0 or T1 (first one: line 4525, G1 Z.45 F30000) and then go straight to the tower. On the U1 firmware that gives 3 travels through the part at layer height and one over the finished top, 91 mm long.
Two controls with the same model and profile: 2.4.1 with the tower 5.6 mm to the left (X230.853) writes the detour and has no such travel, and 2.4.0 with the tower at X236.5 is clean.
I sliced it from the command line on macOS and have not opened it in the Orca window or printed it. The table and the lines are also in issue #1168, where the engineer asked for a 3mf today: 2.4.1: tower near the right bed edge, the new head drops to layer height at the dock and crosses the plate · Issue #1168 · Snapmaker/OrcaSlicer · GitHub
