I built a Home Assistant dashboard for my Snapmaker U1 so I could see what’s loaded, check how a print is going, and get to the controls from the same screen. It’s built on Ironoxx’s Snapmaker U1 Card, which provides the integration and original printer card.
I mapped the four spool positions and toolheads onto the Studio render. The spools change color to match the loaded filament, and the graphic shows live XYZ positions, temperatures, and which toolhead is mounted. Tap the printer to open the controls. The original Cutaway view is still available in the card settings.
There’s also a compact Minimal view and a separate Maintenance & Diagnostics view for service intervals, temperature history, and the bed mesh.
The layout also works well on a phone, with the printer, job status, and camera stacked vertically. The separate Maintenance & Diagnostics view brings together service intervals, temperature history, the bed mesh, and system status.
If you’d like to try it, the setup steps, YAML, and graphics are all available:
The setup guide, dashboard YAML, and graphics are on GitHub. To find the repository, paste this into GitHub’s search bar:
snapmaker-u1-homeassistant user:Reaper2507
If you try it on your U1, I’d love to hear how the setup went.
