Possible Regression in Snapmaker Orca 2.4.1 – Nozzle Scratches Prints During Final Toolchange (Works in 2.4.0)
Hello Snapmaker community and development team,
I would like to report a possible software regression introduced in Snapmaker Orca 2.4.1, affecting my Snapmaker U1.
After updating from version 2.4.0 to 2.4.1, I noticed that the nozzle started scratching the surface of printed objects during the final movement toward the prime tower.
This happened repeatedly with different multicolor models, including a coaster and a layered popsicle fidget toy.
After extensive troubleshooting, comparing G-code files, and testing both slicer versions, I found a significant difference in the final toolchange movements.
1. Problem Description
When a multicolor print finishes, the printhead moves horizontally toward the prime tower.
With Snapmaker Orca 2.4.1, the nozzle appears to move across the finished surface without sufficient vertical clearance, leaving visible scratches.
The problem occurs at the end of the print, when the toolhead moves away from the completed model.
I did not notice this behavior before updating to version 2.4.1.
2. G-code Comparison – Version 2.4.0 vs. 2.4.1
I compared the generated G-code for the same layered popsicle model, sliced with both versions of Snapmaker Orca.
Snapmaker Orca 2.4.0 – Successful Print
Near the end of the print, version 2.4.0 generates:
G1 X133.642 Y121.215 Z12.4 F42000
G1 X71.119 Y172.773 Z12.4 F42000
G1 Z12 F42000
G1 E1.5 F1800
;HEIGHT:0.2
;TYPE:Prime tower
;WIDTH:0.5
; CP TOOLCHANGE START
Technical explanation:
The final printed layer is at Z = 12.00 mm.
Before the long movement toward the prime tower, Snapmaker Orca 2.4.0 explicitly moves to Z = 12.40 mm.
Since the Snapmaker U1 has a vertically moving print bed, this increases the clearance between the nozzle and the printed object by 0.40 mm.
The toolhead then travels toward the prime tower while maintaining that additional clearance.
Once near the tower, Z returns to 12.00 mm.
Physical result: The model printed successfully without the nozzle scratching the surface during the final movement.
Snapmaker Orca 2.4.1 – Scratching Occurs
The corresponding final toolchange sequence in version 2.4.1 contains:
G1 X134.467 Y137.293 E.00156
M220 B
M220 S100
; CP TOOLCHANGE UNLOAD
G1 X76.373 Y178.527
SET_PRESSURE_ADVANCE ADVANCE=0
G1 Y179.277 F2400
Unlike version 2.4.0, this sequence does not contain an explicit Z-axis lift before the horizontal travel toward the prime tower.
The nozzle moves from approximately:
X134.467 / Y137.293
To X76.373 / Y178.527
This represents approximately 71 mm of horizontal movement without an explicit Z elevation immediately beforehand.
If the nozzle remains close to the last printed surface, this movement could explain the scratching.
Physical result: The nozzle scratched the finished surface during the final toolchange movement.
These differences are visible in the generated G-code, although further investigation is needed to confirm the precise cause of the physical contact.
3. Troubleshooting Performed
I performed several tests using Snapmaker Orca 2.4.1:
Changed Z-hop from Automatic to Normal.
Maintained a Z-hop height of 0.40 mm.
Disabled “Reduce Infill Retraction”.
Enabled “Z hop when moving to tower”.
Tested an additional 2 mm Z lift before
PRINT_END. -
Used the default Snapmaker U1 profiles.
Created new projects without using third-party 3MF conversion tools.
Unfortunately, none of these changes eliminated the scratching during my tests with version 2.4.1.
I also compared G-code generated from simple cube models using both slicer versions.
The comparison showed a similar difference in the final travel behavior.
4. Physical Test – Most Important Evidence
After repeatedly experiencing nozzle scratching with version 2.4.1, I uninstalled it and reinstalled Snapmaker Orca 2.4.0.
I sliced and printed the same layered popsicle model again on the same Snapmaker U1.
Test results:
The nozzle scratched the printed surface.
The problem occurred during the final movement.
Multiple slicer adjustments failed to eliminate the issue.
Snapmaker Orca 2.4.0:
The same model printed successfully.
No scratching occurred during the final movement.
The generated G-code includes an explicit Z lift before traveling toward the prime tower.
This comparison strongly suggests a possible regression in the toolchange or prime tower travel logic introduced in version 2.4.1.
5. G-code Files – Google Drive
Since I am a new member of the Snapmaker forum, I currently cannot upload attachments directly.
I have therefore prepared a ZIP archive containing the two G-code files used for comparison.
Google Drive download:
The archive contains:
U1_Orca_2.4.0_no_final_scratch.gcode – Generated with Snapmaker Orca 2.4.0. The print completed without the final nozzle scratch.
U1_Orca_2.4.1_scratches.gcode – Generated with Snapmaker Orca 2.4.1. The nozzle scratched the printed surface.
These files allow the development team to inspect the differences in toolchange and Z-axis movements.
I also have photographs and video evidence of the issue.
6. Request to the Snapmaker Development Team
Could the development team please investigate whether Snapmaker Orca 2.4.1 introduced a regression affecting:
Z-hop generation before final travel movements.
Prime tower entry and exit trajectories.
Final toolchange and toolhead parking behavior.
Retraction and wipe movements during the final toolchange.
In particular, please review why version 2.4.0 generates an explicit Z lift before the final prime tower travel, while the corresponding sequence in version 2.4.1 does not.
I understand that the missing explicit Z lift alone does not conclusively establish the cause, but the physical test results are consistent with this difference.
I have already submitted a technical support report to Snapmaker with evidence of the problem.
For now, I have reverted to Snapmaker Orca 2.4.0, which successfully completed my comparison print without nozzle scratching.
Has anyone else experienced this issue after updating to Snapmaker Orca 2.4.1?
I hope these findings help the development team reproduce and resolve the issue in a future update.
Thank you for your time and support.
